engine carb restoration help
DMCdesign
Master Apprentice
Uttrakhand, India
I had an engine which was in really bad shape. I had started stripping it off and had brought Its carb home. any form of help would be deeply appreciated. here are the photos. it has been sitting with the engine for around 8 to 10 years and its in a desperate need for restoration.
KartFab
Dallas, TX
Good luck. I'm sure someone else can give you good news, but here is some bad news: the white stuff in the bowl is corrosion. If I remember correctly, even if you clean it out, it will come back because it has already started. Other members can correct me if I'm wrong, but that right there would be a sign to replace to avoid future headaches.
It may be salvageable with some serious elbow grease and possibly a rebuild kit, but step 1 is identifying it! You haven't told us what the engine is, and I'm not sure just by looking at the carb.
DMCdesign
Master Apprentice
Uttrakhand, India
Sure, the engine is an old Bajaj Legend 150cc (made in India). this engine is at my late gramps house and I could only get the carb for now.
DMCdesign
Master Apprentice
Uttrakhand, India
replacing the bowl might be a bit of a headache. but I can try a scrap carb without the rust. but I can assure you the rest of the engine is in very good shape. I had cleaned the engine when I had gone to cremate my gramps. though it shed a lot of muck and mud,
the only parts that rusted were the stock exhaust and the carb
DMCdesign
Master Apprentice
Uttrakhand, India
I just posted myself on the map, The whole of India belongs to me right now! and there are so many scrap yards here that practically I can get enough free metal to build a base frame and a bolt on roll cage but originally I belong to Varanasi, Uttar pradesh, where I had gone to cremate my gramps
