sid I thought a caster was thishttps://www.harborfreight.com/4-inch-x-3-4-quarter-inch-stem-swivel-caster-90998.html. can I see a pic of the ones you are thinking of?
hf refuses to show me the image on the link (region locked??)
but I assume we both think of the very same thing being a caster wheel
something like this:
or
maybe you misunderstood the
gear wheel =/= caster wheel
=/= (crossed out equal sign) means not equal of course
What Trevor was talking about (at least how I understood it)
was a powered
friction wheel on the "non gear ring equipped" flywheel
to start the engine up.
such as this (well a smaller version of course...
(only real difference is it has no internal bearings but is rotationally locked to an axle really,
think front kart wheel vs rear wheel
I'm not sure that's a reliable solution though,
the slip (rubber on steel) might not provide enough of acceleration (rather jerk) to engage the compression release on the cam..
and thus it won't have the momentum (speed) to engage the compression release;
and since there's no positive force fitting connection (no gear teeth)
the slip might just increase and the engine still won't turn over.
Anyways..
yes if the predator series is the one you want to go for, then no e-start will be at your disposal I'm afraid.
if you look at home depot however (I'm definietely region locked there)
they should have a 3hp e-start competitor for all I know.
