fowler
Was the disc it came off the same thickness as the one u have
U can't put a calliper off a car on a push bike
I could put a smaller rear calliper instead of a front calliper and then the disc sizes would roughly be the same.
But as someone said earlier. They have less power and don't work until they lock :/
Opinions guys?
The back is only good till it locks up which it will do a lot
A locked brake is ineffective; there's more friction between a brake disc & its pads than there is between the tyres & the surface they're running on. To work effectively, you don't want the brakes to lock...
Thats why you have ANTI-LOCK brakes on cars..... You are no longer in control when your brakes lock. Yes, you can "guide the slide", but you are no longer controling how fast you can slow down n stop. I like a big disc brake n hyd caliper. To scrub off speed in a hurry, I'll MASH on the brake ALMOST to lock up and release, repeating if needed, then apply firm brake pressure to control a quick stop. Its cake walk with a kart considering I also drive BIG RED TRUCKS full of water and tools, and some IDIOT will still pull out in front of us, with EVERY sound and light emitting devices blarring.....I have to be able to stop a 37' truck full of tools, and 8500 lbs of water in a hurry. Locking up my brakes does NOT work. TRUST me.... have cop dash cam video showing our E1 's a§§ end go side ways on my asst.chief today.....'nother IDIOT turned into his lane running "hot"...... idiot got pulled over and took home several souvenirs from the sheriffs office....
