ebay brake kit
Jfive
Great falls Montana
I used the mechanical disc brake kit from gopowersports.com. Was about the same money. Works good at stopping 400 to 500lbs when I needed it to.
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
I have never seen that Kit.
But like J said the GPS one, I have seen, used and know it works
Don't Forget 10% off at GPS (DIYGOKARTS)
Garryjav
joppa md
i could'nt find cable fittings on the gopower site for brake cables?
still would like to hear from anyone that has used a brake like the ebay one
The one from GPS is much better... that other one wont handle the weight.....
Cables/fittings can be sought from a bicycle shop, or get a length of universal brake cable from walmart.... find some fittings from an old bike.....
Garryjav
joppa md
Bike cable is strong enough to use on a foot brake? I would hate for one of the grand kids to make a panic stop and have it snap
It would make for a easy set up as the sprocket is on the left side i could hang the caliper bracket off the engine platform and run the cable under the engine
The Manco karts typically used a 1/4" steel rod for brakes--much stronger than stranded cable and probably a better feel as well.
My dingo has a bell crank right behind the seat that offsets the solid rod so it can clear the TC.
2 pieces of Rod. But the one from the pedal to the bell crank has a dogleg in it where it threads through a retaining eyelet.
I get some flex because of it but it's not too bad.
I think the rod would be cheaper than getting cable and fittings.
Garryjav
joppa md
Thanks for the links. after looking at it again i think i can mount the disc brake on the left side and fab up a rod for it.
My big one has the bellcrank too and uses the same brake as was linked from gopower with a 8 inch rotor and it stops fine
