Jake.B
If i put a 8hp on one side of my cart and a 5hp on the other? Both are Briggs and stratton would it work i cant think of any problems?
and hooked them both up to a live axle?
if its a live axle, youd be fine and top out with the some speed. if not you might have a problem going into a tree. if an 8 hp is at half throttle, and a 5hp is to on single wheel drive, the 8hp side will go faster than the ovtherand youll end up going the opposite of which the 8hp is. live axle would work totally fine
Yes. Certainly much simpler.So you're saying it's better to connect 1 engine to a live axle. Yes?
i have access to 2 5hp B&S engines same model
I'm confused.
