dual motor cart?
Jake.B
California-USA
If i put a 8hp on one side of my cart and a 5hp on the other? Both are Briggs and stratton would it work i cant think of any problems?
and hooked them both up to a live axle?
kendelrk
redneck engineer
westland michigan
if its a live axle, youd be fine and top out with the some speed. if not you might have a problem going into a tree. if an 8 hp is at half throttle, and a 5hp is to on single wheel drive, the 8hp side will go faster than the ovtherand youll end up going the opposite of which the 8hp is. live axle would work totally fine
Brandon1023
needs an oil change
Miami, Florida, Dade County 305
So you're saying it's better to connect 1 engine to a live axle. Yes?
Yes. Certainly much simpler.
Having two different engines will NOT cause you to steer to one side. But the engine with less power will at some point in the torque curve, drag down the engine with more power. That's not to say it "won't work", I just don't think it will work very well.
kendelrk
redneck engineer
westland michigan
i must not have used my words clear enough, even tho its better to have 1 connected to the live axle. im saying that in a single wheel drive application, that is using 2 motors ( 1 on either side), if one is bigger it might cause you to steer to the side because one wheel is turning faster than the other
Jake.B
California-USA
ok thanks, this was just a what if thought and i have access to 2 5hp B&S engines same model and i thought it would be cool
jamyers
Buffalo Gap, TX
You could hook 2, 3, 4, or as many motors as you want/can to a LIVE axle, each one will contribute it's power to the kart.
I suppose you could hook a couple of engines to their own dead axle / individual drive wheels and it'd work... I wouldn't think it'd try to steer the kart too much, since the basic one-wheel-drive karts don't have much problems with the concept.
But I like LIVE axles, and think that it'd be easier that way.
I wouldn't worry about synchronizing the engines, as long as their idle speeds are the same and the throttle linkage is such that they both hit wot with the same movement (which would depend on the governor if you keep it more than the actual throttle).
Heck, 2 5hp's and an 8hp = 18hp...I'm not sure where you'd fit it all, but it'd be a fun ride!
klicky96
Sandusky, Ohio
If you ran both engines together, you would probably blow the 5 HP because you are running the 8HP on a high throttle. The 8HP would put too much power into the 5HP, ruining the motor. It'd be like running your engine on complete open throttle the whole time. You will burn the piston rings and likely ruin the piston.
jamyers
Buffalo Gap, TX
I disagree that the 8hp would "put power into the 5hp", both engines are going to be under a load if the gearing is anywhere near close. If it's revving that high, then gear it up - you'd have plenty of power to get it moving from a stop...
I don't believe it will result in a blown engine, either. Gearing would be a compromise, though. Gearing for the 8hp will be too tall for the 5, yet gearing for the 5 will render the 8 a bit of a waste.
jamyers
Buffalo Gap, TX
Gear it for 13hp, but you always run both engines. If one is down for repair, you'd want some extra gears on hand.
