Driven or Driving?
cjhols
Probably a silly question but for the sake of matching shaft sizes can you put a cent. clutch on the driven shaft rather than the drive shaft??
Thanks
Peter
mindymogul
Mistress of Destruction
Land of Camo and Fireball
He wants to put the clutch on the driver pully shaft.
Answer: No. Even on the most sunny days with perfect of chance that still wouldn't work. You'd loose so much torque ability and there's no point to loose that much power for nothing. Secondly, you can't run the driven shaft without the driven gear. Period.
I still don't get it. The only driven and drivers we can speak about are related to TC's. What do you mean about using a centrifugal clutch on the driven. There is no driven if you are using a CC
cjhols
I told you it was a silly question. But wouldn't the driver come of the engine shaft (driving) and the driven be whatever is driven ? Sorry for the confusion.
How it works is like this....With a centrifugal clutch you have the clutch on the engine output shaft. The chain goes from that to either a jackshaft, or to a axle sprocket. With a torque converter you have a driver on the engine output shaft going to the driven pulley on the jackshaft. They are connected by a belt. The driven has a chain going to the axle sprocket
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
You are sorta correct in your thinking. However the terminology is just off. and Driver and driven are typical terms for a Torqu converter setup.
Hence the confusion.
So for your "Driver" terminology just say "Crankshaft" and your "Driven" is just the "Axle sprocket"
Now On to your original question.
You would have a 7.5" 72 tooth sprocket on your engine and a 12 tooth cc on your axle.???
No that would not work.
Show us some pics of what you are trying to do and Why.
There are no Dumb questions just silly ones:lolgoku:
cjhols
https://www.youtube.com/watch?v=7DaMK_v_Pno
This is what I want to do but I was thinking as to whether I could cut out the T/C and drive the diff by way of a C/C. directly. I am planning to do a ratio of 2:1 (the diff has a ratio of 9:1in top gear already). It has 16" wheels. Would it be ok to use a belt rather than chain?
Thanks
Peter
Thanks
Peter
Clutch on engine crankshaft. 2:1 ratio from crank to lawn mover differential input???
---------- Post added at 05:44 PM ---------- Previous post was at 05:38 PM ----------
Am I still missing something???
9 * 2 =18
18:1 with 16's gives 10 mph at 3600 rpm??
The 9:1 is ok I guess. But a torque converter that makes the final drive ratio in top gear close to 9:1 is closer to what you want. And you'd possibly have to adapt it to fit the lawn mower shaft.
That's IF the transaxle thing can hold up!
---------- Post added at 06:00 PM ---------- Previous post was at 05:44 PM ----------
He has TC Driver unit on Crankshaft.
He has TC Driven unit on a Jackshaft.
He uses sprockets on the Jackshaft and lawn mower trans input.
TC gives range of like 3:1 to 1:1. You'd want same size sprockets on jack shaft and trans input if it is 9:1. Or put Driven unit right in the trans input.
That would give low like 25:1 ish and high like 9:1 ish.
Somebody correct if I am misunderstanding here.
