https://www.youtube.com/watch?v=7DaMK_v_Pno
This is what I want to do but I was thinking as to whether I could cut out the T/C and drive the diff by way of a C/C. directly. I am planning to do a ratio of 2:1 (the diff has a ratio of 9:1in top gear already). It has 16" wheels. Would it be ok to use a belt rather than chain?
Thanks
Peter
Clutch on engine crankshaft. 2:1 ratio from crank to lawn mover differential input???
---------- Post added at 05:44 PM ---------- Previous post was at 05:38 PM ----------
Am I still missing something???
9 * 2 =18
18:1 with 16's gives 10 mph at 3600 rpm??
The 9:1 is ok I guess. But a torque converter that makes the final drive ratio in top gear close to 9:1 is closer to what you want. And you'd possibly have to adapt it to fit the lawn mower shaft.
That's IF the transaxle thing can hold up!
---------- Post added at 06:00 PM ---------- Previous post was at 05:44 PM ----------
He has TC Driver unit on Crankshaft.
He has TC Driven unit on a Jackshaft.
He uses sprockets on the Jackshaft and lawn mower trans input.
TC gives range of like 3:1 to 1:1. You'd want same size sprockets on jack shaft and trans input if it is 9:1. Or put Driven unit right in the trans input.
That would give low like 25:1 ish and high like 9:1 ish.
Somebody correct if I am misunderstanding here.
