Well I was planning on finishing some stuff this weekend since I had an extra day but the wheels showed up but weren't delivered. Have to wait till Monday. Drilled the back part for 5/8 jackshaft bearings. Test fit for alignment and found I don't have to offset it, just turned the clutch around and looks about right. For the record a harbor freight 1 3/8" step bit drills a tight fit for a bearing. I'll need to cut the main rectangle tube down a few inches, weld up my seat mount, install tires, cut Pvc, see if thumb throttle is gonna work, install front brake and weld tank mounts on the back. Hook it all up and test it out without getting in trouble at my apartment.
