***Dont know much about this
Lynx_Genisys
Alberta, Canada
T-man
regarding the pins/valves for the fuel flow...
just take amd hold the carbs upside down, so the float drops, and the "pins" fall into position, then blow through the fuel inlet, (where the fuel supply/hoses flows into..)
if they seat properly and sufficiently enough, you shouldnt be able to blowair through em, or at least not at all easily...
if you can its no good... even if the float and everything operates good, it will trickle fuel in..
and for ezample, say ou park the machine, it will continue to flow, over fill the bowl, build up through the jets and orrafices until it starts flowing out the carb etc..
(the first time i put fuel into the first dingo i got running, it all drained out tho the float bowl, intot he carb, and eventualy into the box of my truck!!! lmao)
if i doesnt seat proprerly, you'e gona have to fix.replace the pins or rubbers on em.. or something...
also tit wont hardly run as it will be continualy flooding out...
(My warrior does this anytime i try to catwalk it.. floods out ad dies.. total buzz kill... *sighs*)
~L~
anderkart
Surprise Arizona USA
ander I did take out the fuel pins, mine look differant then the picture you poster. Mine dont have the rubber tips or the flat head on the pin thats on back. But I'm sure that its still ok.
HellSpawn : I did just that, stuck the air hose up to one end and all sorts of junk flew out.
Cool, some needle valves dont have the rubber tips, glad you got the passages all cleared out.
T-man
Missoula,MT
went out side today and messed around. my neighbor let me use his compression tester so I could see if the engine worked ok. well I hooked it up to one battery the same way I did in the video and the engine just rrrr a few times and then would stop. so I hooked up two batteries ( in par. ) and it did the same thing ... not ever enough time to build up the pressure in the gauge. So I stoped ... my hands were numb from cold, and then I thought, I never checked to see IF it had oil in it. Theres a little window on the side but I couldn't see anything. I knew that If there was oil in it , its probably not to good. So I took out the plug and the oil that came out was BLACK and it took about 10-15 min for it to drain ( but it was cold out ) and when done I noticed that it smelled a little like GAS .... any thoughts?
The Mechtician
Gargamel Jr.
Surrey, BC, Canada
Ice cold batteries don't work as good as warm ones. Either that or they're stone dead :D Get yourself a car or truck battery for testing, it'll crank that little bike engine over no problem! Good call on getting the old oil outta there too! It's common for small amounts of fuel to wash past the rings into the crankcase, if the oil wasn't changed often that would explain the smell. It's either that or the rings are worn right out. Refill it with fresh oil and finish your compression test, then you'll know for sure :D
T-man
Missoula,MT
well haven't done anything with the engine for a while. Way to much snow and cold. But I did go to the store today and get oil for the kawasaki and for the karts.
firekiller52
Flat Head Kinda Guy
nj
i would say take the plugs out and give the cylinders a good squitr of ool(i like atf better, but oil works too) and that seems to get the rings sealing again
i have a 76 kawi kz400 if you need any info i can gather from that, appears to be the same carb setup and wiring stuff, o and your starter is good, they draw a ton of power, atleast mine does
