DIY baby gokart from Greece !
kouvpasir
Greece
I had this in mind a few months ago for my little son (4,5 years old)!
First I wanted to modify his pedal go kart to an electric one! I was trying to figure out the costs and the time will take to make it work!
:idea2:Finally I decided not to destroy his pedal gokart and made a baby gokart from start!
Project start on February 2014 and finished late at June 2014. And here we go....:thumbsup:
kouvpasir
Greece
I did a research on net for plans an pics to find out what exactly I was going to built!
I also put down some rules for my build:
1. low weight
2. low center of gravity
3. low budget
4. electric engine
5. adjustable (on my son's age, kids are getting taller very fast)!
kouvpasir
Greece
kouvpasir
Greece
Everything starts from here.. on my shop's little workshop!
22mm & 18mm steel pipes 1mm thickness (light type)...
also 1/2'' galvanised steel pipe for rear crashbar!
kouvpasir
Greece
I made my own bucket seat from a cheap kid plastic seat , polypropylene and pex alu pex pipes!
kouvpasir
Greece
Building rear axle, seat brackets , paddles and steering frond axle!
kouvpasir
Greece
Rear axle brackets and some reinforcements on chassis...
kouvpasir
Greece
My son helped me building steering column on his kart by adjusting seat on the very front position and the very back position (adjustable seat position) ,
(adjustable steering column angle )
(3 position adjustable caster angle )...
kouvpasir
Greece
disc brake bracket...
...and motor adjustable position bracket
(brushed dc motor --> 250 w 24v geared )
kouvpasir
Greece
brake and gas pedal cable work....
kouvpasir
Greece
batteries (2x 12v 9ah) steel box with rubber insulation...
kouvpasir
Greece
paintwork...
...it's obvious he likes Subaru's colours...
kouvpasir
Greece
Some closeups...
adjustable caster angle-->
adjustable steering column angle-->
brake & gas cables-->
rear axle gear changed with one with more fat teeth-->
kouvpasir
Greece
Side bumpers...
kouvpasir
Greece
Front bumper...
kouvpasir
Greece
Front shield...
He is happy!...
kouvpasir
Greece
Speed Controller & throttle...
Finaly...
