Dirtbox Venom mini-buggy, 40+ horsepower!
greaser
new here
moose lake mn
Congratulations and it sounds like the wedding and honeymoon went great. The buggy is really looking good. 27 cans? You might have to invest in a paint gun soon. lol
mysteryboy28
Lansing, MI
a-arms done, tack welds on the back of the buggy final welded, front shock tabs fabricated.
mysteryboy28
Lansing, MI
seats mounted, and front end progress. :)
supermanotorious
Winchmaster 5000
New River, AZ
this is inspiring, I have all the tools you do and this is motivating me to use them! I would like a little more info on bending the pipe/how much sand/etc and how you're bending the square tube, I did buy some steel to fabricate square bending dies but haven't quite gotten around to it for a lack of knowing how well to brace the inside of the arch, and how to fabricate a seat for the HF jack, I'm guessing a pipe with an I/D that fits snug around the jack...?
also, how do I calculate bend radius for square tube, I'd like to primarily bend 1.25" x .083 wall so would a 6" curve be appropriate? how tight can you bend it?
In other words, is there a known calculation for this? given tube size and thickness as variables?
****, just dont be lazy and google it lol
http://www.bendtooling.com/bending_formulas.htm
mysteryboy28
Lansing, MI
trial and error my friend. as for bending: round and square tube work fine with the same die (round dies). just try to get the square tube as level as you can - and bend! there is always some spring-back when you release the bender. so if you want a 45 degree angle, you usually have to bend to like 48 degrees or similar (depends on what you're bending).
when i make a double curved piece (both left and right sides curved 45 degrees) it usually takes about 8 inches off the total length. so a 60 inch piece would become a 52 inch piece. so you can assume you'll lose about 4 inches on average per side when making a 45 degree bend. that's about as formulistic as i get! lol.
Really? I tried that & all I managed to do was fold it. Could that be because I didn't fill it with sand?
mysteryboy28
Lansing, MI
i was going to make my classic hoop a-arms, but even with them packed with sand the heavy guage tubing ended up cracking just as i got them to the desired curve. so i opted for the classic tried-and-true triangle a-arms. easier to slap a bung bolt in the end of them for connecting the spindles. :)
mysteryboy28
Lansing, MI
n1kogr
Mass
i hate you man i wish i had your skills! Anyways it looks great and the suspension looks solid. I just hope once the rear end is complete (engine installed) that the shocks are not too soft
Stiff, but not too stiff. It's looking awesome, great work.
The trailer looks like it's in better condition than mine was, nice find
mysteryboy28
Lansing, MI
steering and pedals are done. however, one of the joints on the steering shaft fell apart (the caps over the bearings fell off and little roller bearings fell out all over the place). tried to piece it back together, and as soon as i turned the wheel it fell apart again. lost several of the bearings, so i put it back together and spot-welded the caps on. now there's some noticeable play in the steering. doh! i'll email BMI karts and see how helpful they are.
off to bed i go. later tonight i'll be tackling brakes, then it's motor time!
mysteryboy28
Lansing, MI
made the mount for the brake cylinder. cut off the ends of the CV axles and welded on the hubs. welded a hub onto the 50 tooth sprocket.
sleepy time. zzzz...
oh and my buggy wanted to pose for a picture, so...
