txluke
I have 2 Baja Dirt Bugs. One has a 212 haphazardly mounted to it and 1 was original. I decided to put my new in box 79cc predator to use so I decided to attack the stock one first. I can only find 1 pic of the bike before I started. the others were lost in the war I guess. it was blue and rusty. I got after it with a wire wheel and sandpaper. I happened to have 2 cans of safety yellow rustoleum so that is what I shot on it. After I finish mocking up I will probably have it sandblasted and powder coated. I took apart the brake caliper and cleaned it up and painted it. I was going to go with a hydraulic brake but I will see how this works and get the one that bolts right up if I need to have better brakes. I mounted the engine and drilled out some old pitching washers to make an air cleaner adapter. I have a huge exhaust and I might slap that on there with a monster sized air cleaner and call it a stage 8, 79cc. I added a weld to the bearings on the front wheel to see if I can get them out. the spacer inside is flush with the bearings and will not budge. I have new tires to mount on the rims once I get new bearings and paint or powder coat them.
