BirdFanatic
Is anyone better at electronics then i am ? I have this digatron dt-32k1 and the screens are shot in it they go on but not all the numbers show correctly .
I'd bet
Anyways.. chances are it's a very minor problem, like nearly dead batteries.
so first thing, install fresh cells.
But to be sure, how about a pic of the issue..
maybe we can narrow it down
gently push around the edges of the displays...
I don't know the digatron in person, but it appears like a simple 4 char 7segment display,
see if you can bring single segments back to life when you apply pressure.
if so, chances are good the LCD itself is still in perfect working condition and the segments just lost contact to the pcb
happens quite often on segment displays that are connected via conductive rubber, and not soldered in.
if you cannot bring any segment back to life, check if the crystals have been leaking.
easiest way is to use another polarisation filter, one from a broken LCD calculator for example..
if you have, if you don't, shine bright light into the LCD and look from different angles, until you clearly see the traces of the segments.. any splash or blob would be leaked crystals...
you need a replacement display (or tachometer)
no leaks, mayvbe a soldered display with broken connections..
you need to open the case to find out I'm afraid.
You can send it to digitron for repair.......
It's usually a lot cheaper than buying a new/replacement unit.....![]()
