differentials - good or bad
redcali
yea it would depend on your application of the go kart.
for offroad/dusty trail i wouldnt use one
I like karts
Rotary Power!
Alabama
Yeah, I was thinking about getting one of those, but I have the feeling it might slip a little too much in hard acceleration. I like hard acceleration.
kibble
I banned myself
Haven't used the Northern diff, but I did put a diff on my kart. Gives you insane control. Not good if you want to do donuts or peel out a lot though.
Roy Vanas
demon since birth
jr dragster T
Cold place
How is that limited slip if the 2 sprockets off the wheels is locked onto a solid jackshaft? The only thing slipping there is the wheels on the pavement.
redcali
the jackshaft is not solid, it rotates?
note the brakes on the jackshaft. so it is rotating..
jr dragster T
Cold place
I know its a rotating jackshaft. Theres NOTHING to slip there though. No free wheels or clutches so thats aint gona slip.
Roy Vanas
demon since birth
when the inner wheel slows in the corner its clutch disengages & the outer that is spinning faster doesnt!..... the brakes could also be sprotors=(sprocket rotors) "safer" for cheap band brakes use an oil filter wrench!:smartass: revised diagram
GoAlterBridge
A while ago I was planning a street legal kart, for fun, and if I ever actually made one I thought I would probably use a differential.
2or3wheels
Minneapolis Minnesota
i have a diff, not northen but a diff at that on this lawn mower thing(yeas pics comming), and it seems to work fine, all be it it will not break tires loose even if on ice, but its nice, it helps you get speed through corrners because one wheel isnt chattering.
