did i get the right driver?
Bluethunder3320
I bet you I can clean up and rebuild that driven clutch. Unless there is excessive wear you can always rebuild.
well its kinda too late cause we had to cut up a piece to get it off the engine shaft.... i dont get what was making it stick like that. even with enourmous force it didnt budge.
got the nut off the jackshaft.
oh and blaz, this is the TC that the user homemadegokarts1221 was talking to you about.
EDIT: oops meant the driver has a piece cut up. my bad.
Bluethunder3320
the part that is closest to the engine (pulley face) was stuck on the engine shaft so we chopped it up to get it off.
the driver springs are shot ($15ish)
the center piece does not slide through at all.
the outer housing thats supposed to have a double D bore, is scraped to a circle and doesnt hold the slide piece at all....
so its missing too many parts.... i figure ill just get a new one.
i think 20 series are symmetrical.
Blazkowiez
Kart Aficionado
Houston, Texas
The hub not sliding through is a CLEANING issue man. We see that all the time. Yes, series 20/40/88/maxtorque are symmetrical, series 30/99 are a-symmetrical. The 20 on the driven clutch does not have anything to do with the series either.
Bluethunder3320
ok... but still theres alot missing.
i think its cheaper to get a new driven and now i have some parts i guess....
driven looks good as i posted the pic above. tomorrow im going to wire wheel the pieces.
i assume im supposed to lube the bushing?
Blazkowiez
Kart Aficionado
Houston, Texas
Keep the bushing dry, you can spray it with graphite. We clean it off with a sort of thinner, but always wear safety glasses, gloves, etc with dealing with that stuff. Stay well ventilated... I can't remember if you're the one that does go-kart work in a basement but don't use gas or carb cleaner in a basement.
Bluethunder3320
lol yeah i do the fab stuff in the basement......
anyways heres the pics of the 20 series that came. i got the store wrong that i said earlier. i got it from go kart supply not mfg supply.
sent it back for a 30.
