did i get the right driver?
Bluethunder3320
i ordered a new 20 series driver because the old one is not saveable.
it says "20" stamped onto the driven....
i later find out that the "20" may mean the angle of the belt and not the series?
great. :ack2:
ill be :mad2::mad2::censored: if i find out i ordered the wrong driver.....
btw. this setup is out of a off road manco go kart.
EDIT: the reason i cant fix the existing driver:
- the springs are shot (i could buy new ones but theres other things)
- the inner part that is supposed to slide through doesnt move at all.
- the outer part doesnt attach to the slide part whatever its called...
- the back piece of the pulley we had to wreck with an angle grinder to get it off the engine shaft...
Bluethunder3320
ahhhhh are you kidding?? great so now i have a 20 driver and 30 driven.... maybe ill try to stop the shipping on it asap.
thanks guys ill try to get the store to stop shipping it if thats possible...
Bluethunder3320
okay well im just gonna wing it and put the 20 on... LOL just kidding. i wish.
its already shipped so its too late. when i get it ill get a number to exchange it for a 30.
i got this from mfgsupply. good thing the 30 is cheaper than the 20, i think the difference will pay for shipping to have me ship it back.....
r_chez_08
Should be in the shop...
Cornwall, UK
Thats definently a tav2 belt because it is asymmetrical and has "this side to engine" written on it.
Another thing is the driven spring doesn't look quite right- aren't the cam buttons meant to rest against the edge of the "v" shaped bit, not the middle at idle? Maybe the buttons are worn causing the spring to unwind?
the-cyborg
Spring, Texas
Here is some pics if your interested in it, new never used, and a real comet 30 not a knockoff.
Bluethunder3320
maybe he pushed the kart backwards or something? im not sure of this things history... last time it was in use we could not stop and it kept getting stuck into overdrive.
its gone through at least 3 engines (that i know of)
going on its 4th engine (baja warrior)
i have time to take apart the driven and clean it all up... it wont be at least a week until i can place the exchange order for the 30 driver. so i can get parts.
i have just enough money between the worth of the 20 driver i just bought, and cash on hand, to get a completely new TC, i just am trying to save money if thats possible you know....
the nut is rusted onto the JS so i cant easily get that driven off. its going to take some wrenching.
Bluethunder3320
i think its just easier for me to do an exchange. but if for any reason it doesnt work... ill let you know....
thanks!
EDIT: oh and nice trailer! thats going to be an upcoming project. my friend on here homemadegokarts1221 made one out of a boat trailer with bleachers bolted to it for the bed. thats going to be a $800 or so that im not going to spend!
r_chez_08
Cornwall, UK
When you say it gets stuck in overdrive, are you taking driven?
I would dissasemble/clean that driven and check the buttons. If they are ok, check and retension the spring and you should be good to go.
the-cyborg
Spring, Texas
thanks!
If it comes to it, I'll do an even swap on the 20 series, if that helps.
Bluethunder3320
i think it was the driver that got stuck but i might be wrong.
id assume this is terrible for the belt....
im going to try to take the driven off tonight.
r_chez_08
Cornwall, UK
Ok. Another thing you may want to do whilst you have the driven apart is change the spring tension with the holes that the spring goes into. There are 3 settings- fast to high ratio- normal and low to high ratio. If you tension the spring more it means you stay in the "torque" bit for longer.
Bluethunder3320
Whats your distance from center crank shaft to center jackshaft ?
I may also have a belt or 2.
i cant measure now unfortunately because the engine is at my friends and the TC is in my basement.
im going to check out the driven right now. if i can get it off that is :ack2:
we couldnt get a piece of the driver off the crankshaft so we had to go ape on it with the grinder and dice it into little pieces. that was frustrating. crowbar didnt make it move. hammer didnt do anything either.
the-cyborg
Spring, Texas
looks like the belt you got is a 12-8487 on there in those pics, only 30series belts I have are a couple 203592A and couple 40 series 12-13057
