Detachable Steering wheel
Gearstix
Alberta, Canada
How hard would it be to make it so I can remove the steering wheel on my go kart? Right now I have the steering raised up in my go kart so I can get in it easily. But it sort of is a bit high.
Its actually harder for me to get out of this thing because I don't have very good balance.
So if I could detach the steering wheel I could lower the steering back down a good bit.
Here is how it was.
[/IMG]
And how it is now.
It would probably handle better if the steering was lower.
brendonv
Australia, Perth
What about have a uni joint on ur steering shaft, then make the main support beam for the steering column thats usually between your legs on a detachable mount, then u can detach it and hinge the whole steering system up, get in and pull it down and click it back in our put the pin back in or how ever u make it detachable.
The reason for the uni joint is so u can pull the steering assembly up. It will sort of hinge on the uni joint.
