JimD
Just want you to know I did get the driver and the driven. Like the guys pointed out to you they are two different series by Comet. Your driven unit on the jackshaft is 7" and it is a series 20 and it is in good shape other than it needs a good cleaning which I will do and re-lube with a dry graphite. The driver (small one going on the engine) is a series 30 which is asymmetric. You cannot mix the two or you will shred the belt very quickly. The driver unit needs some new springs and a also a good cleaning. Maybe you can find someone to swap with.
When you do put it all back together again the belt should be aligned with the driven unit and the driver unit at neutral. A series 20 always runs much cooler than series 30 because you are NOT forcing the belt up the flat sides of the pulleys, a series 20 the pulleys are working in in unison. Nick -send me an e-mail at Max-Torque or give me a call. Jim
