Dangerous Flywheels Predator 212?
Is that your flywheel Partsguy or some image you found on the interwebz?
Thepartsguy
This thread is called dangerous flywheels and as a smartallic I have to ask what the magnet is connected to by glue and a screw? I’d go buy a lotto ticket after living through this…
When he checked the coil bolts and said they were tight, he was wiggling the coil and it had play in it.
Edit: He loosened the top bolt after checking if it was tight.
Yeah, he had more a sec when he said both were tight after checking with the socket and them it moved. I was going to say! :LOL:
Thepartsguy
He’s a moron for freewheeling an engine like that. For a split second it probably went to 9 or 10 grand and that’s all it takes. Seen morons blow car engines the same way.
An arc flywheel can be freewheeled much higher. With one simple arc flywheel the explosion would have come from the next weak part down the line.
To me it doesn’t matter if it‘s the metal wheel or the magnet from a metal wheel shrapnel off the block like that is a straight up explosion.
But in real life if that had been hooked up to a real load and reved it never would have happened. It only seems to happen when people act stupid.
AGELE55
I give up… where did the magnet go? There’s no exit wounds.
Well that’s the real trick. We expect, from all the hoopla, that the magnet has so much force on it that it pierces the blower shroud and bounces around the room like an errant bullet or goes straight up to your crotch and renders you infertile for life (if you’re behind the handlebars).
Was this Bubba’s engine able to rev to 10K rippems (stiff springs, timing and so forth) or are we just exaggerating?
How come it no puncture the gas can and light it off 💥 like a Hellyweird stunt car (or a Ford Pinto)?
I ain’t skeered, fellas.
Eta: What a doofus, “cam magnet”
:lolgoku:
I saw a different video where the "operator" free reved his engine and the same thing happened. The magnet let loose. But his broke the coil mount bosses clean off.
He had to drill and tap from the other side to replace them to remount the coil.
