Dangerous Flywheels Predator 212?
I've seen the stock connecting rod exit the side of the block but it never got much altitude. I've seen that a lot and that's catastrophic damage so, you know...
Billet con rod is a must (or a priority purchase) I think, over the billet/aftermarket flywheel, as a simple oiling problem and some galling wrecks the rod pretty quick. It overheats and seizes on the crankshaft journal then poof.
Poof what? Finish the story daddy!!!!!!
The crank and con-rod become one when it seizes, so one of them has to yield. Guess which one? The con-rod is welded to the crank journal and then it snaps into several pieces, usually first near the wrist pin where it is the thinnest. Would love a slow motion replay but the pieces become an interference between the block and the crank and they get pushed out through the side.
I think someone said that their rod snapped at the top, disconnected from the piston and then from the shock of that happening, the rod freed itself to turn another 1/4 on the journal and the then mostly intact rod went horizontal like a battering ram on the block. These parts are still aluminum on aluminum so it's still quite impressive.
It's shocking how thin the block is in some places, probably 3/16" to 1/8". :thumbsup: :surrender:
Great now I’m going to have nightmares!
If joshw0000 ever posts autopsy photos in his new engine on his Christmas list thread, I will warn you not to go there. No one should have to see gore.
BlakeCarmichael
Kids, cover your ears... but I heard genuine Honda GX flywheels are considered safer than the stock off-brand stuff, and even maybe tested safe within the 5-6000rpm range (look it up). Just thinking maybe a GX140 or 160 flywheel could run even safer on a GX200, sort of like a Briggs & Stratton 3hp flywheel is said to boost performance on a Briggs 5hp motor. I'm telling ya there ought to be a chart showing which genuine vs. non-honda clone parts are interchangeable. How can ARC be the only game in town?
A compatibility chart would actually be really useful. There are so many GX and clone parts out there that it's hard to know what's a direct swap and what's just forum hearsay.
