CV carb or ignition problem?
Badot
Here's the deal: I picked up an old non-running DR350S on Sunday and fixed it up a bit and got it running. It doesn't like to idle below 2500 RPM. Anywhere between 1500-2500 blipping the throttle is still very responsive with no hanging or dipping and returning when it comes back down, but the bike will seemingly randomly die like a killswitch has been hit within a short time frame. No problem restarting it after.
It's definitely "idling" with the throttle way too far open. It's on the pilot circuit. Carb's been cleaned and the idle mix screw definitely can flow, it just never comes into play because the bike dies first. Couldn't find any vacuum leaks with an unlit propane torch.
My next step is replacing the spark plug, but I'm waiting on a thin walled wrench to get here since none of my stuff fits it. In the meantime, I'm coming here to ask if there's anything else I should look into.
So -- any thoughts?
DHC
So -- any thoughts?
What does the current plug tell you? To rich/lean r u using the right octane fuel? Just acouple thoughts to ask.
Badot
Couldn't say about the current plug, I can't pull it as the wrench hasn't gotten here yet.
The more I think about it, the more I'm leaning towards ignition problems. Would excessive air gap in the pickup cause problems like this?
Recheck the carb.. it IS the carb!
Run fine fishing line through ALL passages to make sure they're indeed clean;
make sure all needles have a sharp tip (not only for correct cut off, also for ideal adjustment)
Prior disassembling the carb again, check all fuel lines and the fuel filter for kinks pinches and clogging, just to be sure though.
Nothing? well then.. carb it is.
the sudden death of the engine sounds more like an electrical problem though...
So whilst checking the fuel lines, check all the electircal wiring for kinks and cracks as well;
loose connections on terminals etc.
sometimes a broken wire does make contact when straightened or bend but looses contact when wiggled around (like driving the bike ;))
Badot
The carb actually got its double check last night. Everything looks in place, no damage or modifications, o-rings in good shape, and everything's clean. Fresh gas, clean tank, new fuel line. Engine runs perfect (although I haven't ridden it) until the revs get too low. Definitely getting fuel, float height is good, and changing the idle mix screw has no effect since it dies before it comes off the pilot circuit. Plenty of flow from the idle jet all the way to the pilot jet. If there's something else in particular to look for, I'm not sure what it is.
I've had my fair share of poorly jetted bikes, and that's why I'm leaning towards ignition/electrical. This doesn't sputter, hunt, hang, dip, etc... just dies. It'll die just sitting and "idling" (no movement), but always restarts with a little throttle blip.
The more I'm thinking about it, the more I'm wondering if it's a combination of heat and low RPM shutting it down. It does seem to be able to idle a good bit lower when cold.
From my understanding, any bad connections would manifest themselves at higher RPM when the load on the system is highest, correct?
I checked the pickup resistance too since that's not an uncommon failure point, it's good. Looking at the design online, it doesn't look like it can back off either unless it becomes damaged so I'll save that for later.
Fingers crossed for a bad spark plug lol.
