Crazycarts crap. #2
Kenny_McCormic
Kartless....
Michigan Troll
Way better than my trike! I could of had a beat to **** 2 cycle ATC 250 that needed points and had a piece of pipe as a muffler for $200, I bought the $7 frame for my low budget suicide machine instead.
crazycart
RedNek Engineering
MINNESOTA
Cut fenders, painted rims & axle, only put 1 wheel-spacer on because i found out that one rim is smaller....Got some alum. rims on the way...studding for ice
crazycart
RedNek Engineering
MINNESOTA
Thought i'd post up my sled since JR. is getting all the attention. :D Just kiddin man......
In this pic a tie rod end is broke that's why the skis look not straight... Nothing goes like 3 holes
Custom Aircraft alum. tie rods (Ski to ski 52 inches wide) Slydog skis, Ohlins shocks all around, Xtra-10 suspension, 96 studs (not nearly enough) Ported track, Nose cone radiator
Its got triple Dynoport pipes (not in pic) Bored .40 over with wiseco's, bored carbs to 39.5 mm, team secondary clutch, run BR9EYA plugs
crazycart
RedNek Engineering
MINNESOTA
Indy 650's are considered to be tanks, but i can lift it just fine....Compared to new sleds its heavyset...
Kaptain Krunch
Pro Junk Collector
vermont
That engine looks a lot like the750 storm engine I got sitting under a tarp. Keep an eye on the injector lines. The engine I got was perfect except for the right cyl which had a melted oil line, which led to destroyed crank bearings and a warped cyl.
Kaptain Krunch
Pro Junk Collector
vermont
So I heard after I got it haha. It's all good though, I made a $25 profit takin it, then another $50 after selling shocks, and I still have tons of parts left.
Kaptain Krunch
Pro Junk Collector
vermont
I'm sure it did but I doubt I kept it, I was about to move so I only kept the most valuable parts. I can check tomorrow prolly tho.
