ok, first off, this is still in the idea phase. here in michigan we have a few sled motors just laying around (acctually they are in the sleds still, but thats remedied easily) anyhoo theres a particular motor that i plan on using in my whacked out idea, a 440 liquid, it propelled the pantera it was sitting in at over 90mph.
the idea was i have 2 motorcycles with the engines all messed up, so what i want to do because i dont feel like fabbing the suspension from scratch is cut the front ends off of both of them, and using a crossbar and the stock mounting areas (just imagine where the front of the bike is mounted to the steering forks) so that i can still steer it, and yet i will have the suspension.
now, there is the front end, but i surely am not finished, see, the rear ends of the bikes are shaft driven, so the idea is to run a shaft with 2 sprockets on it into what will probably end up as a plate of steel from which 2 chains will connect to the drive shafts of the bikes rear ends (i plan on turning the sno-sleds engine and gear assembly sideways so this is all possible)
the steering will be accomplished much like old school trikes plates mounted on the top of the front forks, with 2 shafts coming off each end, connecting to a center plate that will have 2 shafts running to a handlebar, the brakes will be run onto these, one side replacing the clutch handle from the motorcycle. front brakes done, and the rear brakes will be run into a pedal. tell me what you all think, i would love some ideas, or comments, or even no way, thats stupid, this is how to do it.
just remember, i like simple, and even though parts of this seem a bit complicated...they prolly are. i would like to use both rear ends, but any other simpler way of doing this would be appreciated.
