Crankshaft question
l337murd3r
Indianapolis, Indiana
Ok so I got a Firefox 200 for next to nothing and the motor needed to be replaced so not thinking I went to harbor fright and bought one of their 212cc predators when I got it home I found out the crank was about an inch too short so I thought I could swap cranks from the old motor over to the predator tore both the motors down to get ready to swap them over and the gears was different so my question is can I find a crank gear that well fit on the longer shaft needed or is there a longer shaft I can buy for the hf predator
(What I mean by crank gear the old crank has a keyed cam gear that can slide of easy)
Thanks for your time any help would be awesome
Ps if you know how I can rig the hf up without using the old TC and pulley my ears are open
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
Next time ask us before you tear apart 2 motors. Predator 212s are always short on the crankshaft for TCs. Guys just get a longer bolt, and I think there is even a extension piece that bolts up with a longer bolt on ebay.
And your question Yes you could just get a Cent. clutch.
colestreasures
Kentucky
:iagree: and post some pics of what your working on.
Cole
l337murd3r
The motor didn't have no power and the carb need to be replaced by rather then having to spend 100$ on a carb why not spend it on a new motor I could build up if I wanted
Edit: ne suggestions on a crank our solution to this problem lol
The reason I asked as to the original motors condition, typically it can be a few easy things to fix that are wrong. and what carb is costing $100?
Poboy kartman
Senior Moments Member
White Settlement Texas
No...you keep throwing good money after bad. Get a TC....you're halfway there pricewise buying that clutch.....
You probably could have just rebuilt the old carb. What came off the kart clutchwise?
Oh ain't this an ironic topic, V belts again.... Long story... Or just search for recent topics on this...
I think, also as it has been suggested, your buggy needs a cvt not a cent clutch.
l337murd3r
alright thanks guys i was looking at a TC but seen this and thought i'd ask lol
the old clutch was a two piece TC and the HF shaft is too short so trying to make do with finding something that will work
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
Predator 212s are always short on the crankshaft for TCs. Guys just get a longer bolt, and I think there is even a extension piece that bolts up with a longer bolt on ebay..
Again, yes the crank is a little short for the TC but it is ok, just get a longer bolt. This issue comes up all the time and guys just use a longer bolt. So get a TC and the Stock HF predator will be fine.
You were told at the beginning of the thread that you could use a longer bolt. There is no need to look for other options
l337murd3r
with the way it fits on the shaft it would not work with my TC like i also said its a two piece and there was a spacer next to the motor it wouldnt line up even if i tried to use the same one
ML-TOYS
long island, new york
Everyone on here that has a predator and tc has it work. Try posting pics of it on and the mis allignment
