Craigslist SCORE!!
Joe-405
Enjoying New Projects
U.S.A.
I had something similar to that when I was younger. Mine had a fiberglass body, briggs 5hp and a jack shaft system tho. The only suspension was the front end...................... It was a alsport trike
T3clay
St. Charles MN
Right now I'm leaning towards a 13 hp predator with a billet lines cvt but I'm not sure there's enough room for the 13hp height wise specs say its 17.1 inches tall and I only have 14 inches of height
ML-TOYS
long island, new york
Relocate the tank and replace the bulky exhaust and air filter and there should be enough room.
T3clay
St. Charles MN
That's what I thought I haven't ever played with the 13hp I wasn't sure if there was anything els that would get in the way
firemanjim
Just kartin' around....
Houston Texas
Uhh, yeah, I think you should have got it, then asked if it was a good deal....... :lolgoku:
That can be 15-18+ hp, later down the road.....
T3clay
St. Charles MN
Well I decided to pick up that 11 hp predator got it for $150 after taxes anyone have any recomendations for a CVT? Never bought one before where is the cheapest place to get one?
Poboy kartman
Senior Moments Member
White Settlement Texas
Ummmmm.....Once again....for like the millionth time......how would we know when we don't know where you are???????
Try Saudi.Arabia......
:iagree: You can get it to around 13hp simply by changing the air intake & exhaust...
Keep in mind that the 11hp & 13hp are the same block so, the overall external dimensions are the same; you'll still need to relocate the fuel tank; There's absolutely no reason you can't mount it on top of the rear rack... you probably don't even need to use the original tank...
Did you forget your happy pill today, Doug?
What he's trying to say is please fill in your profile :)
T3clay
St. Charles MN
ahh, will do i was thinking of mounting the tank in front of the seat similar to a motorcycle, the back rack wouldnt bee to bad of an idea and i do plan on changing the intake and exhaust also.
