Craigslist Briggs 5hp help
$50 off craigslist and all i did was clean the carb and she fired right up. idles a bit rough and jerks sometimes. and sometimes when i hit the throttle, the motor doesn't throttle up. there's some carbon build up inside the head.
now a little engine ID help, only thing i can gather is that it is a 1996 motor. am i right? here are the numbers;
model#135232
type#0084 01
code#960620YA
I would like to know what carb is on this please.
does the tube on the side have to be hooked up for for proper idle?
does the choke have to be hooked up?
what is the proper spark plug for this motor? (i think the previous owner had the wrong one in there.)
it has the three posts on the shroud side of the head, is this a raptor motor?
it came with a low oil light mounted to the shroud. any way to see if i can still use this?
model#135232
type#0084 01
code#960620YA
previous owner had a MR43T in it
I got it started with the RJ19LM what could this have done to my motor??
definitely going to pick up about 6 of those tank gaskets and a couple of diaphragms. thanks for the advice!
