Craigslist Briggs 5hp
EBACH
va
Craigslist Briggs 5hp help
$50 off craigslist and all i did was clean the carb and she fired right up. idles a bit rough and jerks sometimes. and sometimes when i hit the throttle, the motor doesn't throttle up. there's some carbon build up inside the head.
now a little engine ID help, only thing i can gather is that it is a 1996 motor. am i right? here are the numbers;
model#135232
type#0084 01
code#960620YA
I would like to know what carb is on this please.
does the tube on the side have to be hooked up for for proper idle?
does the choke have to be hooked up?
what is the proper spark plug for this motor? (i think the previous owner had the wrong one in there.)
it has the three posts on the shroud side of the head, is this a raptor motor?
it came with a low oil light mounted to the shroud. any way to see if i can still use this?
jamyers
Buffalo Gap, TX
That looks like your basic Briggs 5hp flathead, I don't know about it being a Raptor as that's a racing engine. Look here for spark plug info; http://www.manddsmallengine.com/briggs/info/plug7.html
Standard Briggs Flatt spark plug is the
The carb is called a "vacu-pulse", 99% of problems come from bad gaskets in the fuel pump (in the side under the little plate) and between the carb and tank. Yours are leaking, soo you'll want a carb kit (couple of dollars).
The tube coming out of the side of the engine is the breather, it needs to connect to the air cleaner end of the carb to keep dirt out of the block.
I know nothing about the oil light.
Hope this helps!
EBACH
va
oh ok, so the raptor must be the motor that has the tilt to it. or looks like it anyways. i just have an aluminum block flathead. thats cool i guess.
i think the previous owner might have been using a OHV plug to run it:eek:
totally forgot to take off that plate on the side and clean that, doh! and yea i definitely plan on getting new gaskets.
just need to work out these couple issues and it'll be my back up:thumbsup:
This is what I get for your engine:
Model
13 – 13 cubic inch displacement
5 – design series number 5
2 – Horizontal shaft
3 – Ball bearing, Flange Mounting, Splash Lube
2 – Rewind Starter
Type (The type number identifies the engines mechanical parts, colour of paint, decals, governed speed, and OEM)
Code
96 – Year
06 – Month
20 – Day
YA – Assembly Line and Manufacturing Plant
The choke does not have to be hooked up to anything, you can adjust it by hand. You engine could be running a little rough due to not having a muffler.
I have the owners manual and parts manual for your engine if you want me to mail it to you. Send me a PM with your adress if you are interested
EBACH
va
yea, the muffler bolts were so rusted they broke off on the first turn. so now i get to deal with that. saw a guy on youtube run his 5hp without a muffler, seemed to idle fine.
zbuck
Ft. Wayne, IN
:wai:Like Jamyers stated, basic B&S engine. The carb. maybe either a one or a two tube. Put the hose back from the breather to the carb. Plus the fact of sucking dirt in, with the carb. opening for the hose open you are sucking additional air, causing the engine to need more fuel. Spark Plug RJ19LM or equivalent. Could not tell if the diaphragm/tank mounting gasket is leaking. Pull the carb. this would be a good time to clean the carb., and lap the side cover and install new diaphragm, install carb. back on tank using two mounting gaskets. Of course clean the tank 1st. As far as the exhaust, is there threads in the exhaust port. If so, use a screw in round muffler.
EBACH
va
thats the first thing i did was clean the carb. i'll put that tube back on.
:ack2: previous owner had a MR43T in it :eek::horse: I got it started with the RJ19LM what could this have done to my motor??
what do you mean by lapping the side cover? i know of lapping the valve seats. it could use a new diaphragm, it is worn where the spring hits it. i just cleaned it with carb cleaner and reused it to see if the motor would start. the tank gasket is definitely leaking, and i think the diaphragm cover is leaking a little bit too.
i sprayed carb cleaner into the gas tank and sloshed it around a bit and it came out clean. so i think the tank is fine.
jamyers
Buffalo Gap, TX
As long as the spark plug didn't physically hit anything like a valve, it hurt nothing.
By lapping, he means to take the carb body and that plate and use valve-lapping abrasive compound on a flat surface like glass to lightly grind (lap) them to ensure they're perfectly flat for a good seal.
If there is ANYTHING wrong with those gaskets, you can chase your tail for weeks trying to get it to run right. You need new gaskets, and I'd recommend a spare set for your shelf.
EBACH
va
didnt see any visual marks where the OHV plug hit anything, so hopefully i am ok.
:iagree: definitely going to pick up about 6 of those tank gaskets and a couple of diaphragms. thanks for the advice!
jamyers
Buffalo Gap, TX
I wouldn't worry about the plug, as the stock plug has its end recessed quite a ways up inside the threaded portion of the head. On my Briggs 8hp flatty I run an "OHV" plug because of the longer thread reach, and the tip of the plug is still up inside the head by almost 1/4".
MR43T is a marine plug, make of an alloy instead of steel so it won't rust. My cross-ref chart shows that it's a much colder-operating plug than stock, where it's about a 9-12 and the stock plug is a 19, where low numbers = cooler plugs and higher numbers = hotter plugs. The stock plug is about as hot a plug as they make, btw.
EBACH
va
the MR43T being a cooler burning plug, could this have caused carbon build up on the plug and inside the head??
jamyers
Buffalo Gap, TX
Yep, sure could have - on the plug at least. The plug needs to get hot enough to keep clean or it'll foul out.
EBACH
va
i bet thats what happened. there was a nice size chunk of carbon on the tip of the old plug.
zbuck
Ft. Wayne, IN
:wai: You also need to clean the outside of tank. Forgot to mention, check the carb. mounting surface on the tank with a strait edge for warp. If warped, you can sometimes pull that area back level. Jamyers, Thank you for explaining the lapping procedure, just to add to what Jamyers stated, I also coat the sealing edge of the diaphragm cover, with dykem and use a fiqure eight pattern when lapping. Also Jamyers is spot on about the carb. diaphragm.
