TheInspiredFool
- Messages
- 143
- Reaction score
- 10
Hey everyone. I have been sitting on this for a bit but figured it was time to make a thread about it to shake things up. As some of you know I am altering a stock Predator 212 Hemi on my other thread. My goals are to keep the internals stock and RPMs limited to valve float but try to improve HP and torque. I have had a nagging feeling as soon as I took off the head and saw how the exhaust valve was placed on seat. The exhaust valve was seated far up on the seat so much so that there was actually a lip of the back side of the valve overhanging the seat face about .040 of distance between the back side of the valve and the face of the seat. This was before I decided to alter the engine. So I put some blue machiner's liquid to see how much of a contact patch I had and where it was on the 45. The intake had an almost acceptable seat contact width but was too high off from the seat but the exhaust had just a tiny line of contact patch and was way high on the seat.
As soon as I saw the exhaust valve and how poorly it was seated I wondered if that was the REAL reason that these engines float the exhaust valve. If the pressure bbuilds up at high RPM it will get under the lip of the valve and force it open. And then at high rpm with such a small contact patch along with the lip I highly doubt it could stay closed at high pressures and high RPM. The more I think about it the more I am convinced that that is the main reason for valve float and not spring tension. I think the engineers built it into the engine for that specific reason for when we disable the governor.
I have heard of guys trying to get cheater springs to get more RPM but when you put them on a dyno they usually make less HP and only gain 200 RPM or so, while some even LOOSE RPM. I personally think that the stock 10.8# springs are plenty for over 6k RPM and that putting in heavy springs just cause loss of hp due to added mechanical work needed to be overcome by the engine. Stronger springs definitely have their place and are needed, but only on more radical applications. Since the valve is out of the seat by nearly an 1/8" it is preloading the valve spring and even with the valve preloading the spring it still floats the valve. And when you bump up to heavier springs it might only give you 200 RPM and a loss of power.
I am bringing this up for discussion because I am a bit concerned that my engine will end up revving much higher than I want. I really don't know how much above 6k rpm the stock flywheels are good for on average. I have heard of some guys turning then 7.5k without problems but I am not that brave, especially since my family will be riding it or nearby.
What are your thoughts on this? I think it could very well be why some can turn 5,800 while others struggle to turn 5k. It could be that one exhaust valve is a tab bit better seated than the other. I am pretty convinced that this is the primary factor in the valve float but want your opinions on this. Has anyone tried cutting the valve seat or lapping them in enough to make a difference to gain more rpm? Has anyone done it and it didn't make a difference?
