Converting Vert. to Horiz.
DeeJee
Weatherfrd, Texas
I see this done on You tube, with a 3 1/2 B&S lawnmower engine. Is this practicle? Will it work with a larger, say 11 HP?
What happens when a governor is removed? I have rebuilt a carb or two, but always hook up as original.
rushking19
Richmond Virginia
Its possible ,but you will have to take the crank shaft to a machine shop to be milled down to fit a regular clutch, and removing the governor will be fine unless you over rev it, and you will have to remove the governor any way because it's attached to the oil flicker and you will have to remove it any way ,but other than that just do what they did in the video on YouTube
