contributing the wisdom: don't have a flywheel puller?
mister twister
TOWER OF POWER is my name
minnesota.
alright everyone just an old engine builder trick for yall.
"the rope trick"
generally used when work requires the crank to not spin.
simply remove the spark plug, and feed CLEAN rope down into the cylinder until no more goes in. then crank the motor until the piston is blocked at top dead center,do what is needed to be done,and to revrse it,simply rotate the crank in reverse to unlodge,and remove the rope.
**great for removing stuck old rusty clutches**
hope this is some help. :thumbsup:
r97
Measure twice cut once
Massachusetts, USA
I know Anderkart has mentioned doing this before, although I'm lost on one thing... how is this method used to replace a flywheel puller!?
sexyvicta
haha yeh i dont get that.
rope trick works well just be careful on twostrokes that the rope doesn't go down a transfer port. Gets difficult after that
kendelrk
redneck engineer
westland michigan
when your trying to remove a flywheel, starter cup, anything where you dont want the piston and such moving ( helps so the flywheel dosent move whilst pulling) you shove a rope down the cylinder ( i turn the engine backwards because thats the way im usually turning) and turn so it locks up the whole motor then your free to take a ratchet and socket to the starter cup bolt and this method is alot of help when pulling starter clutches off old briggs.its another way of locking the flywheel in place to pull it off easier. if anyones noticed its easier to get a flywheel off a shaft when its not moving all over
r97
Massachusetts, USA
Yes, I get how it makes removing the flywheel NUT, but how does this REPLACE a flywheel PULLER?
fowler
Bullsbrook West Aus
wrap one end of a 100ft rope around the fly wheel and the other end to a fast car
flaw the car
this works really well if the rope is infact bungee cord
