mister twister
TOWER OF POWER is my name
alright everyone just an old engine builder trick for yall.
"the rope trick"
generally used when work requires the crank to not spin.
simply remove the spark plug, and feed CLEAN rope down into the cylinder until no more goes in. then crank the motor until the piston is blocked at top dead center,do what is needed to be done,and to revrse it,simply rotate the crank in reverse to unlodge,and remove the rope.
**great for removing stuck old rusty clutches**
hope this is some help.
"the rope trick"
