Confirming Comet TC setup
Iron John
NA
I have read the TC sticky and would like a clarification on the correct way to align the driver and driven pulleys.
My questions are regarding an asymmetrical Comet TC that takes a 203591 belt.
From the Comet tech sheet in the sticky, it looks like you align the 'flat' faces of the rear sheaves of the driver and driven pulley.
From the Stacey video embedded in the sticky, it looks like you align dead center of the driver and driven pulleys.
Which is correct? I assume that for an assymetrical belt, you would align the faces of the rear sheaves, as seems to be depicted in the Comet tech sheet.
Also, what is the tolerance for the center-to-center distance? Are the min-max dimensions absolute, or in practice can they be plus or minus some small distance? For example, if the lower spec is 6 7/8", is 6 3/4" a problem? (I realize that the spec is the spec; just wondering what the real-world acceptable tolerances are.)
Blazkowiez
Kart Aficionado
Houston, Texas
The I usually think tolerance is around 1/8", however do your best to get it right, it really does matter.
You align on the backing plates for series 30, for series 20 you align on the middle of clutches.
Iron John
NA
One question I have is whether I have a Comet 20 or 30. The belt is a 203591 asymmetrical and the driven pulley is 7" in diameter. However, the outer driven sheave says 'Comet' above and '20' below. This is the original setup on a Yerf-Dog 3200 that is a solid 15 years old.
How to definitively identify a 20 or a 30?
Blazkowiez
Kart Aficionado
Houston, Texas
Look at the clutches... series 30 2 degrees inner plate, 18 degrees on outer plate. On series 20 its 13 degrees on both sides.
Iron John
NA
Yipee! :) It's a 30.
What do you figure the tolerance is for aligning the back plates? +/- 1/16"? 1/32"?
