JTSpeedDemon
2019 Build Off Winner!
What do y'all think of this here video:
https://www.youtube.com/watch?v=QEue7ph_DFY
He recommends grinding down the valve stem to counteract compression release. But doesn't compression release only affect the engine at very low speed?
It just seems wrong to me to grind down the valve stem.
And either way, would it even really help with power?
On the same topic: On my HiPo flathead, I've got the #691164 camshaft. It does not have the mechanism on the cam gear to release compression. Is the compression release built into the lobes? My tiller has Easy-Spin on it, and it's the same camshaft number.
EDIT - My Clymer manual from the library just answered most of this paragraph: Easy Spin is built into the lobes, and Easy-Spin camshafts can be identified by two holes drilled into the web of the cam gear. The HiPo cam gear only has one hole in it.
So my HiPo does NOT have a compression release!
That's interesting! It might be a bane to start if I put a billet flywheel on....
That explains why I can so distinctly feel the compression, even turning it over by hand.
EDIT - See post# 6
EDIT - See post# 6
