Russ2251
AZUSA:Powered by LAWN-BOY
Many folks have suggested that I try one of these on my kart. The expense has held me back as I don't know if it will actually fit/work. I think it's time I bit the bullet.
Would this unit be correct for my application? Am currently running about 7 hp with 17 tooth Noram centrifugal clutch and 72 tooth driven sprocket on 11.5" diameter slicks. Works great the way it is but want a little more kick. In other words, I want more "bang for the buck".
Does this unit require a 5/16x24 internal thread in crankshaft to secure TAV to shaft?
I have no internal threads in crankshaft and use clutch that's of straight through design that's held on with 2 set screws that are set 90° apart with 1/4" keyway.
Total weight of kart is just a shade under 100 lbs, including engine and current drive line.
Help on this is much appreciated.
