Hi all.
Noob here...so pls be patient.
My sons 5 hp kart has a comet clutch on it. It was working perfectly for a long time.
Now it seems that the DRIVEN flywheel (not the DRIVER flywheel) is kinda "stuck" in the "high speed/ closed" position. resulting in NO low end torque and burning up belts.
Correct me if im wrong...but seems that when starting out at low speed the Driven flywheel is "open" and the belt is moved toward the center giving you more torque. (correct?)
It doesn't look like the flywheel or spring is broken... but we only have "high speed" now.
QUESTION: any repair thoughts?? or just replace??
thanks!!
Dan
thanks!!
Dan
