comet clutch 500 series
chucksue
does anyone know how much a kart can weigh for a comet 500 clutch. I have built the grand kids a 2/3 model t ford racer and I want to drive it with this clutch.
tazmannusa
Yettem, California
I think it's more HP on the rating, 16 Hp . If it is on the heavy side you need to keep the gearing on the low side so it does not burn the belt.
What is the weight and intended terrain ?
chucksue
the rear end ratio is 2.5 to one. .the tire size is 23 inches in diameter. The weight I do not know. the transmission is a 1932 ford three speed. it will be ran in low gear.
If your ratio is 2.5:1, then you have a SERIOUS problem. Tyres 23"!! Dang. You are not going to move. You need at least a 10:1 ratio or lower
chucksue
comet clutch
the low gear is 2.82 to1 and the rear end is 2.5 to one. this should 7.5 to one from the driven clutch.
I have removed the coil and have installed a car coil.
chucksue
comet clutch
if I had the 29-24-17-15 tooth cluster gear and the 14 tooth main gear then first gear would be 3.52 to one.
may be I will start looking for these or convert to a model a ford tranny.
chucksue
comet 500
I have the picture in the paper clip. I am going to send and hope it shows up.
chucksue
comet 500
I got the governor springs installed and took the car out for a drive. Only had it in low gear but it seemed to run good.
chucksue
I took the racer to a couple
of shows. what a head turner when I open the hood.
I think the car is to heavy for the clutch.
I am wondering if I should replace the clutch with a sprocket and chain and use the 39 ford clutch to engage the drive. any comments?
