I've worked on various motors for years but this is my first time messing with a go kart. The kart is a Manco Dingo that had a Briggs fun power motor with some issues. So I put a harbor freight Predator 212 on it. The Briggs had a Comet clutch setup which I transferred to the predator.
Here's what it looks like when it starts messing up. The belts slips down into the pulley. The pulley is missing some of it's rubber stopper things, I plan on ordering and replacing those.
Here's a shot of how the plates are misaligned. I don't see any way to adjust this. The pulley can't move left or right without throwing the chain alignment off. Can I put another spacer on the clutch and push it all further left? As far as the pulley installation goes, how tight to I tighten the nuts on each side? I'm guessing that too tight is the same as overtightening a bearing nut on a car?
I'm pretty sure I put everything back on the way I found it. You see there's two washers left of the chain sprocket. In the diagrams I'm seeing online it looks like they're only using one, and that would push that plate further right if I went down to one washer.
