Comet belt issues, plates misaligned?
petebert
I've worked on various motors for years but this is my first time messing with a go kart. The kart is a Manco Dingo that had a Briggs fun power motor with some issues. So I put a harbor freight Predator 212 on it. The Briggs had a Comet clutch setup which I transferred to the predator.
Here's what it looks like when it starts messing up. The belts slips down into the pulley. The pulley is missing some of it's rubber stopper things, I plan on ordering and replacing those.
Here's a shot of how the plates are misaligned. I don't see any way to adjust this. The pulley can't move left or right without throwing the chain alignment off. Can I put another spacer on the clutch and push it all further left? As far as the pulley installation goes, how tight to I tighten the nuts on each side? I'm guessing that too tight is the same as overtightening a bearing nut on a car?
I'm pretty sure I put everything back on the way I found it. You see there's two washers left of the chain sprocket. In the diagrams I'm seeing online it looks like they're only using one, and that would push that plate further right if I went down to one washer.
For starters that bronze bushing half of it is completely worn away now and needs to be replaced. It is ok to remove one or both of those washers behind the secondary clutch as long as there remains enough clearance for the chain. You will need to shim out the drive clutch also. The back plates of the clutch need to be lined up parallel. :wai:
petebert
The entire bronze bushing is there, it has slid to the left and is being obscured by that plate. I'll take a look at that when I get home and see why it's able to move like that.
petebert
I put a 3/4" spacer behind the clutch and got a new belt. I installed the belt by making sure the angled side of the belt of the belt was against the angled side of the clutch.
Why are the engine this way markings pointing the wrong way? They aren't pointing at the flat side.
Why does the box for a non-hemi Predator say 55mm = 2.8"?
IDK, I don't think I have arrows???
