comet 40 mounting
gman3850
gilbert az
so after seeing gopowersports comet 40 mounting bracket i got the idea to see if i could mount the plate from the tav 2 on gx390. so a couple of drilled hols later and a couple of colts and spacers ive got the driver and driven where they need to be. now the only problem is that the distenance is 6 5/8 and the smallest comet 40 belt a 31.95 is set up for 7 1/4 so in reality i need a bout a 30.9 belt to work at my distance.
Now i found a belt that is 30.7 length and has a 22 degree angle. the comets belt has a 20 degree angle. do u think this might work. or should i take the time to go down to the machine shop and have them whip me up one that mounts it right at 7 1/4 for whatever metal plus my time is
http://www.amazon.com/Gates-1422V300-Bandless-Multi-Speed-Circumference/dp/B00CJKRT80
and yes it does have room to move without hitting anything
Also:
that belt has no "air time" to cool down, thus it'll be deep fried rubber especially if a serious amount of torque is applied.
That driven unit -if mounted outboard- will need to float to compensate for belt offset.
the closer the two pulleys, the more important this will be.
IDK if the GPS unit is allowed to float or not..
since it's expensive.. I doubt I'd want to be first to try.
what's wrong with a jackshaft *shrugs* especially if it's saving you 200 bucks.
