gman3850
so after seeing gopowersports comet 40 mounting bracket i got the idea to see if i could mount the plate from the tav 2 on gx390. so a couple of drilled hols later and a couple of colts and spacers ive got the driver and driven where they need to be. now the only problem is that the distenance is 6 5/8 and the smallest comet 40 belt a 31.95 is set up for 7 1/4 so in reality i need a bout a 30.9 belt to work at my distance.
Now i found a belt that is 30.7 length and has a 22 degree angle. the comets belt has a 20 degree angle. do u think this might work. or should i take the time to go down to the machine shop and have them whip me up one that mounts it right at 7 1/4 for whatever metal plus my time is
http://www.amazon.com/Gates-1422V300-Bandless-Multi-Speed-Circumference/dp/B00CJKRT80
and yes it does have room to move without hitting anything
