Comet 40 delay engagement
r_chez_08
Should be in the shop...
Cornwall, UK
Is there a way to delay the engagement of the comet 40 tc?
This way the clutch will engage when the engine has a bit more revs and then the engine wont bog as much.
I want the tc to engage at, lets say 2500-3000 rpm?
Cheers
Rob
Yes- the drive unit can be adjusted to engage as low as 1600RPM (factory set up) and as high as 3100RPM. You use a combination of different springs and cam rollers to achieve this. I have a manual for this that details the part numbers. PM me your email addy, and you'll have it in no time.
EDIT- Skip the PM- I still had your email addy buried in my inbox from reported posts. Email sent.
r_chez_08
Cornwall, UK
Cheers, but which email did you send it to?
Also is there a way of moving the spring into a different hole or something on the driven? What does that do?
Rob
Edit: if you send it to pastybloater@hotmail.com it would be great.
r_chez_08
Cornwall, UK
yeah this is an old thread, but I am reviving it!
How do you change the spring tension on the driven of the 40 series? has it got different holes like on the 30 series?
Thanks
For some bizarre reason, my genuine Comet 40 only had one hole, although it IS supposed to have three. (old one, or mfg defect, or something) If yours is a case like mine, I simply drilled a new hole on the smae plane about 45* or so away from the existing hole, in the direction of increasing spring preload.
wall gator
TAMPA BAY AREA
My (4) 40 series driver's only have one hole,never came across one w/3 hole's......:iagree: w/toystory bout drillin a hole ,seem's to me that would work,after all that is how they make the 20 series......why? not just use a stronger spring. WALT
the-cyborg
Spring, Texas
on the 40 series driven it comes stock in the center #2 hole if you want to increase or decrease the delay you will have to drill our the holes for #1 and #3, they are there, but are only partially drilled from the factory.
If you want to delay the drive clutch you'll need to replace the factory yellow springs in the drive clutch with stiffer red springs p/n 203040 which brings the engagement rpm up from 2200 rpm to 2600 rpm before the clutch starts to engage.
