The Noose
I'm sure you guys are sick of these questions but I've read through what I can find on here and watched several youtube videos and I don't think I am understanding what I need to do. Hoping you guys can clarify this issue for me:
I have a yerf dog 3202 that uses the 30 series torque converter. I am swapping the stock Tecumseh engine out for a predator 212.
It seems that the drive shaft on the predator engine is shorter than the Tecumseh's. The splined hub on the driven unit just barely goes onto the drive shaft on the predator.
Is this not a problem? Ive read about people doing something to the spacer to fix this problem, but then It seems like a lot of people don't even really think twice about it and run it as is.
What's the deal? Do I need to modify something to make the 30 series torque converter work with the predator engine? Will it be fine as is?
