jim smith
Hi, I’m a newcomer to the site, so please let me know if this is not an appropriate place for asking for help.
I have a 20 year-old Ken-Bar Streaker that needs repair or replacement of its Comet 30 driven pulley. The problem is that there isn’t a nut at the end of the jackshaft, as in my Manco go kart (see images). Rather, it appears to be a solid bolt. It has a Woodruff keyway, but it doesn’t extend to the far (inboard) end. So, it should have been apparent to me that I would be unable to tap it out from the far end, and in fact it would only go about 2cm, as in the photo. I assume that the sprocket also is fixed with a key, which would also prevent removal of the bolt.
So, is there a way for this geriatric entry-level technician to remove the pulley, or must I just cut through the bolt and get a new standard jackshaft?
I couldn’t find any such arrangement in go kart parts lists. Anyone with experience with it, or the rationale for that design?
Thanks for the help
Thanks for the help
I wonder if someone took apart the driven before and added that.
