Coleman KT196 Bogging Down
cdev
We have a Coleman KT 196. It runs great for about 15-20 minutes then kind of locks up and bogs when you try to accelerate. Once it cools down for a little bit, it runs great and drives great again. Any ideas? TIA
Sparkwizard
Richlands ,NC USA
Is it possible there is grass or a mouse nest inside the cooling shroud?
Was it stored in a barn or outside all winter?
Remove the shroud (The part where the recoil starter is bolted on) and check for any debris blocking cooling air from the cooling fins around the cylinder and head.
Wonder what it was? The only thing you listed that it could’ve been was an air filter issue (clogged probably).
