clutch??
CrazyFazy
well i am going to be selling the cart and just need it to move....lol. I wonder if a 60 would fit? I dont care much about speed i just want it to be able to pull over the **** curb....lol
So i am assuming going from the 45 to a 80 is like night and day then??
jamyers
Buffalo Gap, TX
Yup, HUGE difference...
I'd still prolly be worthwhile to plug your numbers into those equations, just to verify what you've got, and you could enter a low rpm like 2,000 and see what speed it works out to - if it's over 10-15mph then you'll know the gearing is out of line.
CrazyFazy
without knowing what gear will fit i cannot do this right? Or am i missing something? I would just be happy if the cart would do 30 mph and get there quick...lol
CrazyFazy
ok using 2000 rpm and 13 inch tires with a 72 tooth driven gear and a 12 tooth engine gear i come up with 12.858 Is this good or bad then?? Does this mean the cart would only go 12 mph or what...lol
jamyers
Buffalo Gap, TX
That means that with 6:1 gearing and 13" tires, when you hit the gas and come off idle (usually 1800rpm or so) the kart has to go from 0 to 12mph in a near-instantaneous 200rpm jump - I'd think that'd take a lot of torque and a great clutch, that's why yours is bogging down and smoking the clutch.
Hmm, plugging my kart's figures (7.2:1 gears, 14-inch tires) 2000 rpm gives me 13.8mph and 3500rpm gives me 25mph, which seems right - my kart had a tired Briggs 8hp, was a dog off the line, but felt really fast once it was flat out. (Remember, 6 inches off the ground makes 25mph seem like 60 in a car...).
So...with the current 4.5:1 (WAY TALL) gearing, your kart wants to go just over 17mph at 2000rpm, that's a HECK of a jump! My guess is that the former owner has a CVT (torque converter) on there, which would have lowered the drive ratio from a stop down to something like 9:1, and then he'd have 9mph off idle, 30mph at 3500rpm, and even faster without a governed engine pulling more rpm.
I'd say you've got 3 choices, each with it's own "cost"
(1) gear it down, using a jackshaft and/or different sprockets. $50-100
(2) get a CVT (torque converter) = $150-200
(3) sell it as is = no money outlay, but likely lower sales price.
CrazyFazy
so if i stuck with a bigger sprocket your saying i would need one even bigger than a 72 correct?
jamyers
Buffalo Gap, TX
I'd shoot for somewhere between 7.5- or 8-to-1 gearing. With your existing 10-tooth sprocket on the clutch, a 72-tooth axle sprocket would give 7.2:1, which should work (might be on the tall side, but it'd be close). An 80-tooth axle sprocket would put you right at 8:1, which should work fine.
Assuming you've got (or can make) the physical room for the larger sprocket.
CrazyFazy
modifications are no problem as i am good with a welder. If i went with a 80 tooth where can i order it and what info do i need to know. I am thinking shaft diameter.....bolt hole configuration and possibly what size teeth on the sprocket is that correct? My teeth are 1`/2inch apart what does this mean when ordering the sprocket? Thanks Jamyers for all your help with this.
CrazyFazy
ok cant seem to get any help from any of the cart places. My sprocket can be 8 1/2" before it hits. My teeth are 1/2" apart center to center. My shaft is 3/4" wide and it is a 4 bolt pattern that bolts up to my brake clutch. I need to know the od of a 72 or 80 tooth sprocket but it seems no one knows. I dont even care any more if it fits or not as i have a cutting torch and a welder....lol
qtband
St. Louis, MO
You need a 40 or 41 pitch for the sprocket. Get on ebay and find one that's nearest what you need. You can always drill new holes in it and bolt it up. Of course, be extra careful when centering it up. I searched for a 72 tooth and found one that you could fab up for $19.99. If you email them and ask, they'll tell you the diameter.
