Clutch sprocket issue
jwilson17w
Hi all, i just got a old single drive kart from a buddy and figured why not put it together and play in yard with it. Went to Harbor Freight got the predator motor, went to a kart shop and guy gave me a #40 chain cause he said thats what my clutch was. I have a 60 tooth sprocket, have no idea what chain goes on it. I think its bent anyway so was going to order a new sprocket. Can any help me on which one? Im new to this stuff. Dont want to order wrong one....Can get more pictures if anyone willing to help, thought i was going to get to play today lol
JTSpeedDemon
2019 Build Off Winner!
Texas
First off, measure the distance beteeen two opposite bolts on your hub that the sprocket bolts to. That measurement in inches is your bolt circle. Most likely it is 2 13/16" like mine.
Then go online to www.ombwarehouse.com and look for sprockets that match your bolt hole pattern. Make sure the tooth count is within 10ish teeth of the current one, otherwise you might screw up the gearing.
I thought my kart would be a quick fix too, but that's not usually the case.
Can we see some more pictures of the whole kart? Maybe someone can ID it.
---------- Post added at 06:17 PM ---------- Previous post was at 06:16 PM ----------
Oh, and MAKE SURE you get a sprocket for 40 chain!!
jwilson17w
Sprocket is 2 7/8 from hole center to opposite hole center. I will attach some pictures of kart maybe someone knows what it is.
