Clutch/Sprocket Gearing Help
StudNut
Central Valley, CA
I am almost finished with a little project for my son and would like some advice on gearing it properly. My son is fascinated with Hummers...so I built him one out of wood (as a soap box derby car). When he turned 8, I decided to put a motor under it (I stole it from an old Sears lawn edger). I am not sure of the size of the motor, guessing around a 2hp Tecumseh with a 1/2 shaft. I have an 11 tooth clutch and the sprocket on the live axle has 50 teeth. The rear tires have a circumference of around 33" and the diameter of the tire is around 10". The kart will putt around with him on it (slowly) and if I try to ride it, it won't budge without a push start. I'm not sure of the motors rpm - I a short video of him riding it with full throttle below http://www.youtube.com/watch?v=08erAPAPJOU The kart is pretty heavy (about 100-125 lbs) and I would be another 200 lbs if I were to ride it. I tried to fit a 3.5 B&S motor under it but there is not enough room in the engine compartment....that's why I went with the smaller motor. Any advice would be appreciated
the-cyborg
Spring, Texas
Well it looks like it's doing just fine for him and he looks to be having a blast.
Now tell me you ain't trying to put your 200lb self on a already heavy chassis and body with a 2-2.5hp engine hoping that it will pull you around? :roflol:
HEHE get your own cart and leave his alone.
StudNut
Central Valley, CA
Thanks.....and yes....I tried....just to bring out the kid in me again....maybe I'll have to build a larger scale model for me next summer
machinist@large
West Michigan, 49331
:bannana::roflol: I have to agree with the 'borg; nicely done build. Sorry to hear about the curb weight, thought. Question; what did the rear axle originally come out of? Cheers!!:cheers2::sifone:
Blazkowiez
Kart Aficionado
Houston, Texas
Mega Props of being a good parent with that one man. That kid looks super happy. I have to ditto what the cyborg is saying... the engine simply doesn't have the torque to support the added weight of the kart and you. It would be the same if you attempted to ride a doodlebug mini-bike.
anderkart
Surprise Arizona USA
Kinda looks like you'd have enough room under there for a 6.5hp overhead valve engine. With the angled cylinder and the fuel tank removed they're probably shorter than your current engine. For your fuel tank, I was thinking you could mount a 1 gallon metal gas can on the tailgate to simulate the 5 gallon Jerry cans you used to see on old jeeps and stuff.
