Well we certainly have members under 20.. we have mebers that are not yet considered teenagers..
That messsage you got is likely somewhat out of date considering the "most of our members are"
it should now read "Some of our members are..."
Frankly the POINT of the message is: "do not swear"
And that's still valid.
Aaanyways...
you might have some knowledge.. okay, that's good.
You will certainly not have anything close to our COMBINED knowledge though,
since that is literally impossible.
That's the whole deal about forums.. combined knowledge.. you can't beat that as an individual.
Anyways,
to your problem...
You asked a question that without exact details is hard to answer perfectly correct ont he first go.
What exact part is on your jackshaft (we would need a pic to identify it... descriptions no matter how good will cover several types of drive
n pulleys)
kevbo assumed a series 30 since that is most common.. and if it indeed is.. it's the correct answer.
could be a different style TC but is still is a Torque Converter for sure
(comet 20, 30 or 40.. 770 790 cat 99.... boring endless list ended prematurely here)
And yes.. a driver unit of any TC works because of centrifugal forces (centripetal if you're going to nitpick on physical terminology)
And yes.. it clutches as well as variates so you have a zero speed on idle engine speed.
True!
It is still NOT considered a centrifugal clutch; not because that is not describing it's function, but because a centrifugal clutch is a term used for -well- centrifugal clutches already, and thus it can be misleading terminology.
it's called a TC Drive
r unit or Driver Pulley.
It ALSO variates it's active pulley diameter based on the centrifugal force and counteracting forces of the driven unit.which cannot be done with a cent clutch (neither belt nor chain)
just to be as unambiguous as possible.
No, you cannot run a driven unit with a fixed sheave pulley, (at one point it'll open up and slip)
you MUST connect it to a driver with a tc-specific belt. no way around it.
(well no way that will work properly in the end that is)
Sure you can now just assume any of us is not half as smart as you are...
but even if that's true.. we're now 6.. and combined we're three times as smart as you (see.. combined knowledge is great)
So, if you want to do it correctly, post a pic of your driven unit, let us identify it..
in case kevbo's first guess was not perfect, we can link you to the Driver you need and you end up with a well working kart transmission.
Or you can do whatever you felt was a good idea before you asked, then fail and grief come back and start over first...
your choice, but ask yourself what's a wise decision to make.
Again a tensioner type pulley (lawnmower and such) will NOT work with any variable diameter pulley on the other end, not for long nor reliably that is.
here's why... you tension the belt so it's in good contact with the driven... the kart runs,
all is fine.. you come to an incline (say you go up a hill, or try to just climb a curb or something) the torque needed to do so is greater than the torque needed to run a flat paved road.. sooo the rear wheel will work AGAINST your driven pulley (tries to stop it)..
Now it's a battle of forces... the spring that keeps it's sheaves together vs the friction building up..
the path of least resistance will win.. chances are the spring loses and just opens up the sheaves enough to release all friction... engine revs, belt smokes, kart stops.
...and you lost!
If you want to stick with belts...
Two fixed, or two matching variable pulleys.. everything else is dumb. (sorry, but it is!)
feel free to test it if you wish.. but it's on you to prove US wrong, not the other way around! It's you who disagrees with common sense
Also.. NEVER use a throttle stop to limit speed with a TC or cent clutch
both need a certain rpm at which it fully locks.. and that must be met in order to not ruin the clutch itself or the belt.
Luckily. a series 30 TC can be had with an optional speed limiting weightset
http://www.gokartsupply.com/speedr.htm
And to use that would be the smartest move.
gear the kart to the 20mph for the bigger kid, then use the weights for the smaller one,
to limit the speed.
