japandrags
- Messages
- 1
- Reaction score
- 0
hi guys im new here , and i just bought a go kart for project but i think i have missing some parts and need to know what to do , and what clutch do i need , any help i will apreciate thanks!!!
I had 5 horse B&s with a to short pto. I went and bought a half inch drive 13mm socket and used a section of that as a bushing. So i cut it to lenght( use a chop saw they are hardend steel) Then put the clutch on, and bolted it down it worked great.
P.S i had to grind a flat spot on the socket so the key would slide over it , pretty simple task just bring your clutch along, and mesure your pto thickness. My shaft was 3/4 an inch and therefore that socket worked but if yours is a different size just bring your clutch to a hardware store that sells individual sockets and test some and figure the one with the least play.
Also my clutch was a hillard extreme duty, so im not sure if this idea is compatible with all clutches
